After install new 1.9.8 EOS family offline.
It lost ION offline.
I can only select EOS or Element offline.
Where ION is?
That's weird.
Where ION is?
That's weird.
And the why part.... Eos, Gio and Ion have exactly the same feature set. They differ in physicality and output capacity only. The shell was starting to get a bit crowded with the introduction of Gio. To that end, we put all three products under the tile "Eos family." Element is kept separate as it has a reduced feature set. The offline software is now a blend of the Eos virtual facepanel and the SKs that you would see using an Ion. That way Ion users can easily find softkeys where they are used to them.
Hope that helps.
a
Hope that helps.
a
