Couple of suggestions for 1.9.9
Hi. Got a couple of things I'd quite like to see (if they're even possible!) in v1.9.9, or maybe the release after that if I've missed the boat!
In the Ext Links column of the PSD, it would be nice to see a bit more information about effects in cues. For example, if I have four groups of channels running four different effects (1, 2, 3 and 4), the Ext Links column just shows E1+ regardless of how wide the column is. Would it be possible to expand this so that it says something like E1,2,3,4 (or similar) if the column width is sufficient to fit it in, collapsing to E1,.. or E1+ as the column width is reduced below what's required for a complete list?
Also, when using a single screen on an Ion or RVI (there isn't usually the space for two screens on an LD's table!) could there be a way to zoom in and out of the PSD portion of the display? At present I can zoom in and out of the live table section, but not the PSD. Even if it's something as 'clunky' as switching to the PSD tab, zooming out on that display, and then having that zoom level carry through when I switch back to live split table?
Thanks.
