A couple of 1.9.8 questions
Hi all
I was wondering if someone could help a little niggle of mine - I have patched colour scrollers onto 20 or so channels as Part 2 so that I can patch the intensities onto Part 1 when I come to the production week next week. However, when I log off/switch the desk off and back on, the scrollers are now on Part 1. However if I do patch a dimmer to Part 1 then the swap doesn't happen, so I was wondering why this happens?
Also, with the new shift button, would it not be possible to access the grey 'more sk' shortcuts below the CIA by pressing Shift & shortcut key instead of cycling back and forth using the 'more sk' button?
And as I'm here, will ETC ever add a coloured bar to the Playback Status to show which is the next cue to be run upon pressing the GO button as I find when cues are linked out etc it really isn't clear at a glance which is the next cue in the playback.
Cheers.
  • Hi Stu
    Point 1 is a very annoying bug which will hoping be fix in a release next year.
    Nick
  • Does it matter?
    I'm not mistaken they will operate the same way, unless you specifically call for the channel part. This is the beauty of functional mapping of the addresses.
  • Personally, I prefer to have the scroller/whatever accessory as Part 1, because then it shows up under that name in the live table instead of just saying Dimmer - If you patch VL1Ks with an external dimmer and you make the dimmer part 1, the live table just calls it a "dimmer". But that's just me.
    However, to get around this, I'd just suggest patching part 1 to some high address that's far beyond what you're using - something like 20/400. Then when you get your dimmer numbers, just use [Replace] to put the correct dimmer numbers into Part 1.
    Hope that helps!
  • The only reason I do like to have the scroller patched to Part 2 is it's quite handy when sending out a tour that might not have a production electrician/relighter, to have a sort of blank template show with the scroller (or other fixture) patched to Part 2 so when patching the house dimmer you can just type chan 1 @ address 1/75 (for instance) and it'll automatically patch to part 1 and not remove the scroller off that part in the process.
    Yes that's what I thought I'd have to do - will work as a temp fix and hopefully the bug is sorted at some other point.
