Should one be able to write a Macro using Enable and Disable with Capture?
When you double tap capture, it posts Capture Enable to the command line, but if I write a Macro that says Capture Enable or Capture Disable, it doesn't do anything. Am I doing something wrong?
Ion 1.9.6
