1.9.8 clarifications, please
Hi ETC, Anne
I've installed 198 on my Ion / RVI, and need some help with some of the changes.  **I** can't make some of the commands work.
1. Mark Time: I can set the Mark Time in the Set-up, but I can't over-ride it with a discreet time applied to the parameter.
2. I can't [Shift] & [move encoder wheel] to post pan/tilt to the command line.  [Shift] & [Encoder page key Beam / Focus] does post it.  This may be affecting #1.
3. [Shift] & [Full] doesn't turn Flash on.  It will bring the channel to full while you hold the buttons down, but releasing the buttons clears the channel back to its original state.  In my mind, this isn't the same as the {Flash} command.
4. [Shift] & [Select] will reset the display columns.  I can't get Shift & Up, or down, left or right to move or reszie columns on the Cue List screen.  Shift & Level Wheel doesn't resize columns here either.
5.  I have snapshots for adjusting the monitor output.  Using those snapshot now (with 198) leave the CIA open at the bottom, since (I think) the CIA was open when the snap shot was recorded.  Tapping [Display] twice will clear the CIA.
6.  Maybe I'm not clear on the Independent Sub thing.  If an Independant sub is at 0%, it DOESN'T override other subs.  If I move an Ind Sub off of 0%, the levels of the affect channels jump down, and then roll up normally as per the Ind Sub.  Is this expected?
7. Goto Cue 5 Time {minus links} Enter gives me an error beep at the {Minus Links} keystroke.  This is an actual instruction in the ETC paperwork.
8. Cue 1 Park Enter gives me an error beep at the Park keystroke.  Is this a change?  I haven't used it previously, but the original 1.7 manual says it should work.
9. Is there some way the Timing Disable command can latch on again, rather than being the momentary (2 finger) command?  It seems easier to get to, now, but the toggle was nice.
Thanks.  If it's just me, let me know where I'm going wrong with these commands.
I like the improvements (Macros at power up/power down), saving and updating by sub bump buttons.  Thanks.
Will 1.9.9 be of much use for Ion users, or is it only for Gio users?  Will any changes affect the Ion?
Thanks very much
Andrew Riter
Chan Centre.
  • Hi Andrew,
    A few answers possibly...
    1. Are you applying the discrete time to the source cue as normal or the reference cue, if it's the source cue this should work (at least I have had it work during the betas)
    2. It should be [Shift] + [Press Encoder Wheel] rather than move I believe.
    3. [The behaviour of [Shift]+[Full] is as intended, when you release the keys the channel goes out, the same applies for the [Shift]+[Out] combination but in the reverse.
    6. Yes, that is the intention of independent. It forces it's priority over other playbacks, subs etc.
    7. Probably a stupid question, do you have any links on cue 5?!
    9. Timing disable should latch on by pressing [Timing Disable] + [Load] (for the playback you desire it on), the new [Timing Disable]+[Go] is in addition to this.
    Hope that's of some help!
    Cheers
    Dan
    [edited by: dsmurfin at 3:23 AM (GMT -6) on Thu, Jan 12 2012]
    Aha.  Thank you.
    Aha. thank you.
    Funny.  The command line says "Flash On", but the lamp and channel come on but don't flash.  Sometime the channel locks on, and sometimes it doesn't.
    I was just surprised it didn't work on when the fader handle was out, and that channels jump instantly to its control.  I'm guessing it's not used in Live setting much.
    Yes.  In this case, 4.1 time 20 is [Followed Time 40] to 4.2 time 20 [Followed Time 40] to 4.3 time 40, [Followed time 40] to 4.4 etc.  I had thought that Minus Links includes Follows and Hangs. Is that incorrect?
    Aha.  thank you.
    Thanks Dan.
    Anyone else from ETC able to respond on the remaining points?
    Andrew Riter
  • Hi Andrew,
    3. As Dan pointed out above, this is intended behavior.  However, it is a known bug that releasing Shift before Out or Full won't return the channel to its previous level.  This will be fixed in the next release.
    4.  Hmmm.  Investigating that one.
    5. I'm not sure what's going on in this one -- was the Browser not popping up before?
    6. I believe this is expected, as independent rolls back to the previous control source.  If you'd like them to remain fully under the sub's control, you'd want it to be Shielded instead.
    7. Also investigating that.
    8. I don't believe that it is possible to park a cue currently, but I could be mistaken.  It may be possible under the Group Cue x syntax, but I don't think a cue is eligible for parking.  Also, it would only be a channel selection tool (i.e., wouldn't recall that cue's levels if not currently the active cue).
    EDIT for #8:  I've found this in the 1.7 Operations Manual.  Investigating.
    Hans
    [edited by: Hans.Hinrichsen at 9:00 AM (GMT -6) on Fri, Jan 13 2012]
    Just realised what is going on... since 1.9.8 the console now automatically runs follows/hangs when you do [Go To Cue] X [Time] [Enter]. The {Minus Links} softkey is there if you want to prevent this happening. If you do [Go To Cue] X [Time] X [Enter] the links aren't automatically run, so there's no need for {Minus Links} hence the error.
    Cheers
    Dan
  • Andrew, looking into the column resizing issue.  At the moment, the CIA is always included in the snap record.  We are looking to add a substantial amount of additional granularity to this in the future.
    Cue n Park enter is not supported syntax, but group cue n park enter is.  Will have the documentation checked on this.
    Thanks much!
    a
  • Just realised what is going on... since 1.9.8 the console now automatically runs follows/hangs when you do [Go To Cue] X [Time] [Enter]. The {Minus Links} softkey is there if you want to prevent this happening. If you do [Go To Cue] X [Time] X [Enter] the links aren't automatically run, so there's no need for {Minus Links} hence the error.
    Cheers
    Dan
    There is a conflict with the associated paperwork, then.  In the 198 release notes, it states on page 4 that (paraphrasing):
    "Goto Cue  5 Time Enter will use that cue's time, AND trigger any links.  Use Minus Links to just get to that cue."
    Goto Cue 5 Time MinusLinks Enter (as spec'd in the release notes) doesn't work.
    Goto Cue 5 Enter will take you to that cue, without links, but in the Time specified in Set-up.
    Goto Cue 5 Time [enter length of cue here, once you've looked it up] Enter will do what the Release note implies, but you need to physically insert the correct time into the command.
    I'm guessing either a bug, or a bug in the writing of the manual / release notes.
    Andrew Riter
    Hans
    3.  Shift On, Shift Off:  I guess I'm quibbling with the description vs the intention vs the name.  It temporarily turns the channel on or off, but it doesn't FLASH.
    5. CIA in Snapshots:  I don't recall the CIA always popping up when I recall a snapshot.  I find it annoying now when I lose half of the cue list or channel page each time I recall one.
    8. gotta love trying to keep manuals up to date (that's one of the reasons I brought these up, trying to keep my in-house short manual (now up to 18 pages) up-to-date.
    Thanks everyone.
    Andrew
  • Hi Andrew,
    You're absolutely right! This should work as documented, and it certainly did at some point during the beta, but it's not now!
    Anne, [Go To Cue] X [Time] {MinusLinks} is throwing an error, you can only use {MinusLinks} with a straight [Go To Cue] X {MinusLinks}, but this doesn't/shouldn't run the links anyway.
    Cheers
    Dan
  • At the moment, when entering a "compound" go to cue instruction, the time button must always be entered last.  Time is looking for a number or an enter immediately following the command.  We can write this up to make more flexible in the future.  But as long as you always remember to use Time (if needed) last, the syntax will work.
    Will review the documentation and correct in the 1.9.9 supplement.
    thanks much!
    a
    [edited by: Anne Valentino at 8:26 AM (GMT -6) on Wed, Jan 18 2012]
  • Ah, yes!! That will be useful for a certain LD we have in this week...
    Cheers
  • So,
    goto cue 5 {minus links} time enter
    will use the cue's time, and not follow any link, or follow/hang commands.
    Thanks.
