Desire patch/ I-Master
Hi
i'm preparing an Element to play with a few desires and a few Revolutions.
But i think a found a mistake in the Patch of the desires.
I used this one: Lustr+ HSIC +7 Strobe
I need the Red Shift, colour temperature and all seven colours, so i thougt this would be the best way.
When i now put the colours manually to "min" the value is -100. Home is 0. This caused some big problems yet, but ok, this one i was able to fix.
In this patch, home for the colours is DMX 128, user min-100, user max100. Might be wrong, isn't?
Also, using the single colours there is no effect on Hue/sat and the colourpicker. If i put H/S to a blue and than use the single colours to do a red, the picker is still blue with that values von H/S.
Is there a chance to change this?
Further there were some Intensity-Masters.
Works pretty well, but when non of the Bump-Led is flashing anymore, still a sub gives values to my Desires. The + under my fixtures in live are still yellow, even if use " Go to Q0". Askink "About" about who is sending that value, it first says for example "S27", ok double press S27, than still "S22", double press S22.. ohh another one, S23..... sometimes 3-5 Sub are stil sending values.
Is this a user problem or is the concole doing some weird things?
thanks
Lukas
[edited by: Lukas at 2:22 (GMT -6) on Thu, Jan 26 2012]
  • Hi Lukas -
    Regarding the Desire fixtures, the mode you have chosen will use Hue, Saturation and Intensity as the color control inputs, the +7 functions are for adjusting (or "tewaking") the individual LED circuits once you have chosen a base color using Hue/Saturation. This is why they home to a middle position, allowing you to add or subtract a little "red" from your Hue/Sat mix, for example. If you truly want direct control of the seven colors to do your color mixing, please change the mode of your fixtures to "Direct".
    I hope this helps.
    Thanks -
    Sarah
  • Hi
    no it doesn't help so far. I need that "colour temperature" fader.
    I have changed the home and dmx values now. This is.... ok.  I now understood why it behaves like that, but wouldn it be better if you see your changes on the colourpicker an H/S values to?
    Do you have an idea regarding the i-masters? I myself could work with it, but a client, who hardly knows about lighting and consoles, will have to use it.
    Lukas
  • and another little problem has come up
    i tried to copy colours from revolutions to desires.
    group 4 contains 2 revolutions, if i copy it to my group 3(desires) only the first to take the values i tried to copy... why does my console do this?
    if i normaly use group3, all desires are involved.
