Is there any way to move the column layout on the playback status screen? I want to move Label so it is adjacent to cue number column so it's a bit faster to read at a glance.
Thank you!
Thank you!
There is no way to move the columns around but you can try shrinking the other columns down to bring the label columns closer.
You will however not be able to see the other information.
