Strange Problems with AutoMark
I'm using AutoMark and working in CueOnly Mode, Version is 1.9.8.
At the last two shows (a ballett and a concert), i need to reorder the cue list, because
we changed the sequence of the acts.
I do the reordering using the "Cue x MoveTo Cue y" Command. After reordering, some of the Marks
doesn't execute anymore. In Blind the Mark was registered correctly but when i start
the cues nothing happens.
I need to make some special cues to solve the problem and it cost me a lot time.
stefan
  • There are no known issues with automark and moving cues. To be clear, you are saying that the automarked cues were correctly noted in blind after you moved the cues, but when you ran the cues, the lights didn't automark.  What exactly do you mean by "nothing happened?"  Did you get a live move instruction?   Were the cues correctly identified as an automark in the PSD?
    If this is repeatable, it would be most helpful if you could email a copy of your showfile (anne.valentino@etcconnect.com), then attempt the move and let me know what channels you had a problem with.  We will investigate and see if you've run into an issue of which we are unaware.
    Thanks much!
    a
  • It was a problem with v1.9.8, with 1.9.9 mark work well.
    stefan
