snapshots, cue info, blind to live
Hi ETC
I've noticed previously, and also now with 1.9.8, that changing from blind channels back to live will not restore the screen to it's previous appearance. (1 Ion, occassionally 1 RVI, 1.9.8)
I have a snapshot that sets the channel layout to 1 x 200 channels, grouped by 5, etc.  The cue info at the bottom of the page is modified: time columns shortened, Link Loop etc reduced, and Notes lengthed to read more.  When I go to blind, next and last through cues, then then go to live again, 2 things occur to the Live screen.
1) the cue info at the bottom has re-formatted to default (the times and link loop etc are widened, Notes is shortened), and
2) the channel display has scrolled down so the top line is something like 160.
Running my snapshot will restore the cue line, but it doesn't re-set to show channel 1.  I have to scroll back up, or grab control of channel 1.
(this was also noted in a post on Nov 30, 2010, and SCR# 16209 from July 2011)  Any progress?
Also, was 1.9.8 supposed to allow moving Playback columns, but that didn't work?  the manual and release notes imply that, but I can't make that happen.
THanks.
Andrew Riter
