FYI:
Fixture profile DL3 v2.0 Global Function...
[OUT] does nothing if channel is at full
if fixture is at any level other than full [OUT] puts channel to full.
Thank you!
FYI:
Thank you!
Thanks for the info.
According to manufacturer, the fixtures intensity is suppose to defaul to Full which is how to profile is set. However, there is a bug that Eos isn't allowing intensity to default to Full. This is why when you say [Out], the fixture either stays at full or goes to full. I will get the default written up.
In the mean time, if you go to the Fixture Editor, copy the profile and edit the Home value for Intensity to 0. You can use that edited profile and it will act like I presume you want it to.
