I would like to use my ION to trigger my Congo Jr. via Midi Show Control. How do I go about setting this up? Or is it even possible.
Thank you.
Thank you.
At the Ion:
Turn on MSC Transmit in [Display] > {Settings} > {Show} > Show Control
Set the MSC Cuelist to the right cuelist number.
Ensure the ACN MIDI Transmit ID matches the MIDI Output Group/ID you want to use.
- The MIDI ports on the back of the Ion are configured in the Shell > Settings > Local I/O
Ensure the MSC Transmit Channel matches the Congo jr's MIDI Show Control Device ID.
At the Congo jr:
Turn on MIDI Show Control in [Setup] > Show Control tab.
Ensure the MIDI Show Control Device ID matches the Ion's MSC Transit Channel.
Programming both:
Plug the Ion's MIDI Out into the Congo jr's MIDI In.
Now, Goto Cue 1.0 on the Ion will tell the Congo jr to Goto Preset 1.0 on the Main Playback.
So when programming, ensure that the Cue Numbers in Ion match the Preset Numbers in the Congo jr
