Best way to program this show. Previous tracking issues.
I guess to start I'll just say I'm new to lighting (relatively) and the ETC Ion is the first board I've ever used.
When writing cues for our shows we have a tendency to set one or two base scenes and a base black out. Every cue we re-record one of the base cues as the next cue. Possibly make some changes, then we would copy in the base black out cue. We would do this over and over again for hundreds of cues.
We often ran into problems where we would go back to a random cue edit it and unwanted things started happening, crazy things tracking through to certain cues, whats the best way to avoid this? Would recording things cue only help, or copying the cues instead of re-recording?
Also is that the most efficient method of writing all those cues, for example our last show had three base cues, one scene on stage left, one scene on stage right and a blackout. It would go in a pattern, Left, Blackout, Right, Blackout, Left, Blackout and so on and so forth, are their better ways to achieve things like this but faster and without possible tracking problems.
Is the method I'm using not suggested or not the common way to do it?
Kyle
  • The common way to have a "base cue" that's used all over the place is to use a Preset for that base.
    - Probably an Absolute one unless you want an edit to that Preset to automatically update all the cues that used it. (Very useful sometimes!)
    Tracking only makes any difference when you go back and and or edit stuff. It has no effect otherwise.
    The main thing to remember about Tracking is that things stay exactly where you put them until they are told otherwise.
    - So if you go back and tell them to be somewhere else, they'll stay there.
    Therefore, when you do go back and make an edit, just ask yourself one question:
    "This change I made, is it only for this particular cue, or is it for the whole scene?"
    If it's just for this cue, then you should record/update Cue Only, otherwise Tracking.
    - The [Track/Cue Only] button will pick the other one from whatever you've made default in [Displays] > {Setup}
    The other tip is to "Block" your blackouts (and the top of each scene if not a blackout).
    - Blocking is a way of saying "Everybody shall move to these places" in a cue, so it's how you tell the console that tracking Shall Not Pass.
