I know why, they make LED's do RGBA at 100%, however is there a way to make the home of the values 0 instead? for now I just did a home preset where they live at 0. Is there a better way?
JG
JG
Copy the profile you are using and change the home values.
why do they make rgba led's 100%?
To prevent the mindless complaints of failed equipment. (done it myself)
When you first bring up the slider you are raising intensity at the default color.
All colors at 100 is white. All at 0 is black. Even at full black isn't very bright.
Either rewrite the profile as suggested, or just use a Home Preset.
-Tim
Thanks, just copied profile and change home values, learning alot with the more fixtures I get.
JG
