1.9.11 is available for Open Beta
Hi everyone.  We are currently beta testing 1.9.11 - this is not a feature release, but modifies/extends existing behavior.  1.9.11 has been in the field for about 1 month and is slated for release the second week of May.  Major changes include:
Source 4 LED support
Message on Primary/Backup when master has changed.
Clients automatically reconnect to new master when master has changed.
External alpha-numericr keyboard:  Condition of Scroll lock enabled/disabled maintained through a power cycle.
External alpha-numeric keyboard setup option to enable/disable Space Bar from acting as a Go.  Hotkey combination to toggle state (Control + G)
Partial Patch Import
Pan + - n now valid syntax to remove "n" from current pan (or tilt) setting
RFR enable/disable now macroable
Addition of All M-Speed to parameter tiles
Ability to overlap two discrete delay times
Go to Cue Out removes all background values
Addition of an improper shutdown message on next power up.
If you are interested in helping us with this testing, please email me at anne.valentino@etcconnect.com.  When you do so, please include your user name on these forums, as this will be needed for access to the 1.9.11 beta forum.
We will advise where to find the code and provide access to the beta test forum.
Thanks so much!
a
[edited by: Anne Valentino at 10:12 AM (GMT -6) on Thu, Apr 12 2012]
