hello everybody,
we need a Query for all green channels in a cue?
Thanks Jörg
hello everybody,
Thanks Jörg
Hi Jörg,
Assuming your Green channels are deriving their color from a color palette:
[Query] [Color Palette] X [Select Active] [Enter]
Hope that helps.
-M
When you say "green channels", are you talking about channels that just faded down in intensity (as opposed to blue channels that faded up), or channels in a green color palette?
If it's colors in a green palette, see above.
If it's channels that have faded down in intensity, I don't believe there's a way at the moment. What are you trying to do with the channels?
This is why I should never post before my first cup of coffee... Jörg, if you are looking for all channels that move down in level in a cue, sadly, Sam is correct that there is no way to query just those channels at this time. You can [Query] {Moves Only}, but that will select the Blue *and* Green channels (which may be better than nothing — you could also append that query command with Flexi-View Channels to get those results on as few pages as possible to make it easier to see which channels move down). You can also Query a specific level such as [Query] [@] 0 to show you everything that has moved to 0 in the current cue.
-M
Hello everyone,
Thanks for your reply.
I want to explain you an example.
green channels meaning channels they fade down.
2 Facts at first.
1. I have created keywords for my channels in patch. To identify them from their position. Like FOH or Stage etc.
2. I have a cue with channels from all positions. some fade down(green), some fade up(blue) and others are tracked (magenta).
I am looking for the following syntax:
query is in cue x move to down and FOH.
I hope thats informal news.
best regards
Jörg
Hi there. Query by down fade (or up fade) is on the list of query extensions.
a
Thanks for reply
Greeting from Weimar/ Germany
Jörg
