CIA Direct Select Module
I am running an Ion on 1.9.10 in single monitor mode. I have a Direct Select Module in the CIA which i use for Macros. With this "Starred" this is now a great programming interface and suits the very small control area i am in much better than two monitors.
One problem, when I restart the console each day, I still have the Direct Select Module, but I have to manually reselect Macros .... EVERY time. This is not only very annoying but also seems illogical. Surely if the module is there, it would make sense for them to retain their contents until you actively change them.
Am I being thick or is this normal ?
