Cue not Firing Prorperly
Version 1.9.11.30
Ok here goes...
we had our final dress for the current dance concert today and after running some cues we went into first cue of list.  We did this by hitting go on cue 277 which is linked to cue 0.5 a worklight cue.  at half hour we hit go into (preset) cue 1.  We started the show ran cue 2 and 3 then the first piece cue 4.  channels 53 through 84 showed that they where up at full but they did not come up on stage.
After the show we did some futzing and discovered if we back into cue 0.5 from cue 5 the show runs fine.  But if we go forward from 277 we get the same oddity of channles showing level and not coming up on stage.  I did not try running forward from go to cue out and pressing go to run the list.  Though i am pretty sure when it happened last night that is how i got to top of list.  (it happened last night and i just assumed i had manual values on the channels)
  • Hey Ed.  We are having a bit of a difficult time understanding the sequence of events here.  And it isn't quite clear if this is an output problem or a display problem.  When you say channels 53 thru 84 showed that they were at full but they didn't come up on stage -   where did they show at full?  On the live display?  What color were the values displayed in?
    Can you drop me the show file?  anne.valentino@etcconnect.com.
    thanks!
    a
  • Not completely understanding the problem, but putting hard values in cue 0.5, i.e. the blue zeros, and blocking and asserting cue 0.5 will probably get rid of the issue, seeing that "going to cue 0.5" or backing up into it (which is the same in the boards world) fixes your issues.
