Delay issues with overlapping intensity FX
Just tried adding a delay to an intensity effect that ended up with the effect not playing back at all. setup: 1.9.11 cue 1 list of channels running fx1 cue 2 same channels running fx2 run cues in sequence and the fx do some xfading and run properly. now add a delay to fx2. update the cue and run cues in sequence. fx1 fades out and fx2 shows delay but list of channels in fx2 is empty. fx2 disappears as soon as delay is done. goto cue 2 and fx running properly. run cues in sequence and fx2 does looses its channels and doesn't run. UPDATE: I guess I should say that I'm not looking for a work around. I believe this is a bug. I'm just trying to post enough details so it can be reproduced. Thanks for the suggestions.
[edited by: Druuka at 6:30 PM (GMT -6) on Thu, May 31 2012]
