EOS: channel selection bug in Blind Tracklist
Hi!
Today we did the update to 1.9.11.9.0.31
Now we have an issue in Blind Tracklist.
Flexi Mode "Selected Channels":
If we select a group, very often the tracklist shows only the highest number of the group, or no channel, especially when we select one channel und next time select a group. With Arrow left we can bring the whole selection to the Monitor. But if we do not, and we create a channel mask, the channel mask seems to be empty, it is not shown to the monitor. Hitting Format 3 times brings the tracklist with the right channels to the monitor.
Can anyone reproduce it?
We have an RPU as Master with a Backup and a Client EOS. This behavior comes on both EOS-Consoles
Servus, Reinhard
  • We can reproduce this problem here where the speradsheet display is empty and it will be fixed. The problem happens when you toggle from live to blind and blind is in spreadsheet mode with a flexi channel mode enabled. The fastest worakround is to just press left or right arrow once after enetering blind to refresh it.
  • Hey there,
    nothing new from this side but same software version same bug.
    I'm not absolutely but almost shure that sometimes the trick with the arrow keys isn't working if flexi-mode is selected only. Don't know if it makes any difference that I^m working with a german translation version.
    Hope you'll fix it soon  'cause it's very anoying.
    Thx a lot!!!
