I have four Eliminator Stealth Beam that I want to add to my patch but the library only shows the Wash beam. They seem to have the same 5 ch or 16 ch needs. Can I use the wash beam info for the stealth beam?
Hi Chris,
Would you be able to provide a manual for the Eliminator Stealth Beam (including it's DMX chart) so that I may submit it to the Eos programming team? I would like to add this fixture to future additions of the Eos fixture library. If you need this profile sooner than 2 weeks please let me know.
In the meantime, it is possible that another profile (if it is using the exact same DMX channels/parameters) will work for you. You may also want to call ETC Technical Support to have someone walk you through building your own custom profile if the Eliminator Stealth Wash does not work for you and you need a profile immediately.
Best,
Therese
6165.Stealth Beam (1st Ed.).pdf
Hi Therese,
Here is the owners manual for the Stealth Beam. Thanks for your help.
Thank you for your quick response. I will submit this request now.
Best,
Therese
