4530.401-MANUAL-1.10-de-en.pdfHi looking for a file for a Eurolite LED PIX-6HCL LED Bar for this week if possible?
Many Thanks In Advance
S
S
depending on the mode you're looking for the PIX-12 in the library should be identical or at least close enough to be edited easily.
this is probably also your only chance, as fixture requests within 20 hrs amost never work out. regular turnaround is 2 weeks...
Thank you, will give it a shot.
New to ETC so wasn't sure of turnaround.
if you need help with editing the fixture reply here which mode you want to use and i'm sure someone will have a look
Hi Sandy,
I am submitting your fixture request to the Eos team. Do you still need this profile earlier than 2 weeks or do you have a working custom profile now? Additionally, what mode are you using this profile in? If a rush fixture profile needs to be made we will want to make sure we are creating your desired mode first. Please let me know so that we have an appropriate deadline of when this profile needs to be finished.
Best,
Therese
Hi Therese
Thank you for the information.
I have not included them in the rig for this show, so there is no immediate requirement.
The two week turnaround would be fine.
With Best Regards
Sandy
