Wasn't able to find the new Chauvet Solo Batten in library 2.8.1.2. https://www.chauvetprofessional.com/products/colorado-solo-batten/
Best,
Best,
Hello,
It looks like there are several profiles for the Colorado Solo Btn (HSIC, RGBAW, RGBA, RGB, etc) available in current Eos software. You will want to make sure your console is running v2.8.2 with v2.8.2 Build 9 fixture library version. Please let me know if you have any further questions or concerns.
Best,
Therese
like this fixture there are others where the word Batten in the product name has been replaced by Btn. which is to put it mildly less than helpful... i can think literally of no instance where replacing a word in the product name with something that is not actually part of the name would be ok. it makes the whole concept of the search function useless.
Clay Paky Show Batten 100, Martin Rush Batten, Elation Cuepix Batten and many others...
Thanks Therese, I’ll try again with the abbreviation.
ueliriegg Clicky Eos team is looking further into a bug that might be preventing Eos from searching abbreviated/unabbreviated fixture names, but in the long-term this profile and other batten profiles like the ones mentioned above will be unabbreviated. Originally Eos had an issue displaying larger fixture names, but as this is no longer a problem we will be removing the arbitrary abbreviations.
