Missing mode in profile for ADJ vizi BSW300 - the “frost” channel should have 3 modes. Off, Aperture, and Wash. It says wash but it just goes into aperture mode. Tried updating the profile to no luck.
Hi Tyler,
What version of Eos and Eos fixture library do you have running on your console? Could you also link me to the manufacturer's manual with the DMX Chart for this profile where you can see this discrepancy. Once I have these materials I can check in with the Eos team on editing this profile to adhere to the manufacturer's specifications. Thank you!
Best,
Therese
Therese,
I'm having the same issue on Eos 2.8.3, library 2.8.2.11 (which I believe is the latest). As I understand it, the fixture has three modes and should zoom some within each mode. Instead, it's stuck on aperture mode and pops between 3 sizes. I'm using 17-ch mode but I think the same issue exists in 20-chan mode. I've tried resetting chan 12 and removing its ranges, but that makes no difference. The editor won't allow me to remove the "diffusion mode."
Manual available on the download page here: https://www.adj.com/vizi-bsw-300
Sarah
Hi Sarah,
The most current software version for the Eos fixture library is v2.8.3 build 5 (download provided in link below). Please let me know if issues persist in this version as well. Thank you!
https://www.etcconnect.com/Products/Consoles/Eos-Family/Eos-Ti/Software.aspx
Best,
Therese
Just DL'ed build 7 and installed (it didn't pop up as an installer option in the shell, btw; I had to browse and select it manually). Same issues exist. Zoom 1 is actually the largest size; at 8 it pops to a smaller size; further up it pops to Sharpie-level zoom.
Hi Sarah,
I think the Eos profile needs to be rewritten for the Diffusion Mode virtual parameter to affect the Frost (or Diffusion) parameter correctly. Sending these suggestions to the Eos team for a fixture library update. Thank you!
Best,
Therese
Therese,
There are also some missing lamp control options for move in black enable/disable, etc.
