need some fixture profiles please
If possible could I get fixture profiles for the following devices by 7-Oct-2019?  If that's too short notice, tell me and I'll explain to the powers that be.
http://www.drbear.com/lights/LED_Mini_Moving_Head_Light.pdf
http://www.drbear.com/lights/LED_PAR_Light.pdf
http://www.drbear.com/lights/Mini_Moving_Head_Gobo_Light.pdf
http://www.drbear.com/lights/moving_heads_1-2.pdf
http://www.drbear.com/lights/moving_heads_3-4.pdf
Regards,
Jack Wilkinson
  • Hi Jack,
    It looks like some of these profiles have already been added to current Eos fixture library software (v2.9.0 build 44). The rest of the profiles, I will forward to the Eos team with a deadline of Oct 7th and let you know if they are able to find existing profiles or create new ones. Which modes out of the below profiles are you looking to use? Is there a name for the manufacturer of these fixtures?
    1) Please look under Custom - Tom Shine Mini Moving 4in1 and Tom Shine Mini Moving 6in1
    2 & 3) Was unable to find a matching profile in current fixture software build.
    4) This profile looks similar to the Beam Lighting's Beam 230W, but I believe the ranges differ. I will submit this request as well.
    5) I believe this is the same as Custom - 7r 230W Beam (16ch and 20ch modes).
    Best,
    Therese
  • Hi Therese,
    None of the documentation or packaging or unit labels had any manufacturer information for these fixtures.  I tried building the profiles myself and while they made the lights "move", not predictably, nor with the expected results.  :-/
    1) will check into it.  thank you. i'm looking for the 16 channel mode so i can get the UV color option.
    2) 4 channel (RGBW) is fine.
    3) 10 channel mode is good.
    4) thank you for passing this one on.  it's another one that my efforts failed at. the documentation mention 20 channels, but only outlines 16 channels.
    5) the docs mention both 16 & 20 channel modes, but then further down they both seem to be the same, so 16 channel.
    Thank you for getting back to me on these.  I appreciate it a lot,
    jack
