This fixture is already available. You will need Eos version 2.9.1 and the current fixture library update (currently build 33) that you can find here: https://www.etcconnect.com/Products/Consoles/Eos-Family/Eos-Ti/Software.aspx
When I follow this link (or simply use ETC's software search), I'm coming up with build 17, which doesn't seem to have the ERA 400. What am I doing wrong?
Build 17 is the main Eos Family Software v2.9.1 which must be installed first, and then the Fixture Library Update which goes on top of that is build 33 or higher, a little further down the page.
Thank you!
