Looking for Augment3d 3D Model.
Eos 3.0
https://www.chauvetprofessional.com/wp-content/uploads/2018/10/ROGUE_R1X_Spot_UM_Rev3.pdf
Eos 3.0
Hi cspulock,
Thank you for submitting a fixture model request. 3D models require much more information and time than standard fixture profile requests. Unless the manual provides exacting detail and dimensions, in order to create a 3D model, we often need the physical fixture in order to model it for Augment3d.
Model updates are released as a part of full software releases and are not available in fixture library updates that release in between full Eos releases.
We've added your request to our list and hope to include it in a future release.
For a list of expected 3D models by software version, please visit: https://support.etcconnect.com/ETC/Consoles/Augment3d/Eos_Fixtures_with_Augment3d_Models
Kirk
Much of this information is available in the Vectorworks library, and is typically present on manufacture's websites, so presumably that information is publicly available. Maybe ETC could partner with Vectorworks to provide relatively accurate models since it seems to be such a common request? Or, maybe the Augment3d Vectorworks plugin should transfer that information...
Hi sktusing,
Thank you for the suggestion! It is definitely on our list to make the process for adding fixture models easier in the future. I'll add this suggestion to the possibilities of future implementation.
Thanks Kirk!
