Please add the Artfox Vista 20R to the 2.9.X fixture library.
I only need Standard Mode.
https://www.dropbox.com/s/xlvfybvn2ishvbk/VISTA%2020R%20CMY.pdf?dl=0
- Dave
- Dave
Request submitted!
I tested this and something isn't right. Looking at the channel assignments, it doesn't match the documentation. For example, channel 6 should have lamp on/off and channel 8 should be dimmer.
I see in the notes that there were some questions about how some feature should work.
Is it possible to have someone look at this again and also add the simple mode?
I uploaded the documentation again here: https://www.dropbox.com/s/r0gvwrvgksrjok8/VISTA%2020R%20CMY.pdf?dl=0
If it's helpful, I have a personality for this fixture for another console and it works perfectly. I've confirmed that the assignments in the document match the working personality. I can share if needed.
- Dave
I have passed this along, I will let you know if they request the show file with the functional profile!
Thanks for your help. How will I know if/when this is fixed? Since the fixture is already in the library I can't easily check that list.
When fixture libraries are released, there is an accompanying PDF titled "Fixture Library Information" that includes a list of fixtures that were added/updated since the initial release of that software version.
Additionally, when searching for a profile in Eos, if you select {Fixture Notes}, it will show you the last time that profile was updated
Yes - I forgot about the Fixture Library Info PDF. That will clarify things. Thanks.
