Profile Error Correction Request - Stage Right Stage Wash 7x 12Watt 15 Channel
Hello,
Could you please make the following corrections to this profile:
1) The zoom in Augment3d is backwards - when fixture control zooms wide to 60 degrees the representation is of narrowing, and when you tighten up to 8 degrees the representation shows widening.
2) The pan appears to be reversed as well in the 3d model. When pan parameter is adjusted from encoder, Augment3d always displays it in reverse to real life. I have tried all 3d orientations, rotating 180 degrees, invert pan in patch and nothing works. Inverting pan in patch doesn't work as a solution, since it reverses what the real fixture does AND what the Augment3d fixture does, the physical fixture and Augment3d are still performing mirror operations of eachother, just inverted from before.
Thank you,
