I need a fixture profile for the Elation KL Fresnel FC. . I'm running Gi0-5 v2.92x.
You can find the DMX-Chart here:
The Standard (12ch) and Extended (19ch) Mode would be nice to have.
Leo
Leo
Hello,
These profiles are currently available in our latest v2.9.2 fixture library update on our website. Please install this and you should see these profiles in the list on the console.
ok
Hello,
today i had a closer look at the KL8 FC Fixture while we Focused our lights.
The Manual says not 100% clearly what the default Values should be.
But the current Fixture in the Lib is not adjusted correctly.
And i have some Tips to spare.
What i noticed in 7ch Mode:
- Color Temp. range should be from DMX24-85 (2400-8500K)
-> currently the Range is wrong and resultes in wrong Kelvin Values. (See Page20 and 24)
-> having a default of 6000K (like on Page15) would be ok. Because the Value of 0 as default resultes in no output when bringing the Fixture to Full and that is quite disturbing.
- The Dimmer Curve Parameter probaly should be a Control Channel
-> ijust wrote Elation today to ask them, but it totaly looked like one to me.
Running v3.1.3b8 on Lib v3.1.5.11
With kind regards
thilda
Hello, i asked Elation about setting the Dimmer Curve or what ever can be found in the "Control Channel"
The Answer was:
"you would only need to select the value for about 10 sec.
then the light will change the settings"
Therefore i would make it a Control Channel and not a Dimmer Curve Parameter.
