2 Channel Mode is most used. Thanks
Hi jonahstarkey ,
This request has been submitted!
Due to a substantial backlog on profile requests, it is likely to be several months before we can get it created and into a fixture library patch. If you are in need of this profile quickly, you will be best served to create it yourself in the Eos console software. If you have questions about this, please contact ETC Technical Services.
I took a look at the manual and if you're using 2ch mode, you could use Generic LED ICt 8B Cold Warm until we get this rolled into a future library
