The range in the default profile for Solaframe 750 Shutter Assembly is wrong. It should be -45>45 Home: 0. But it is -36 to>64 for some reason.
afaik, this is on purpose because the framing shutters are not hoizontal in the center of FrameAssembly's range. so having this asymmetrical range assures that FrameAssembly = 0 will produce horizontal shutters.
This is correct.
But when I use the default profile, the frame assembly is crooked at 0, and it was fixed when I changed the range to -45>45
