Hello,
Need the fixture profiles 20ch, 27ch and 54ch of the CLF Poseidon Wash XS.
Version 3.x
Quite urgend. Need them thursday 28th of July.
Thank you!Manual-CLF-Poseidon-Wash-XS.pdf
Hello,
Version 3.x
Untested!
Some Parameters need to be used with [Shift]+[Encoder Wheel]
I tryed to create a Color Wheel, but after 32 Colors ETC stopped me from going on...
So you can insert a Color Wheel, but only have a fragment of all the possible Colors as Thumbnail available. Sorry.
Fixtures:
Poseidon Wash XS 2022-07-28 03-35-11.esf2
Documentation:
Hope this will be of any use.
If you have any problems, you can write me.
yours
thilda
Hi Mathilda,
Thank you very much for your effort and the fixture file!
We gonna use it this weekend. I will let you know when there are problems.
Cheers
Hello,
- i was able to fix the missing Color Wheel (know 189 Colors have a tumbnail)
- i also edited the Color Wheel Values (for the Color Temp 2500k<10,000K)
- Fixed a little issue with the DMX values for Color Rainbow 5 (Colormacros/Color Wheel)
While attaching the Color Wheel to the Fixture, a "Advisory" will appear on the screen.
This can be entered with OK and be forgotten.
The Color Wheels need to be attached manualy. It is called "Creativ Lighting Fixture - Poseidon Wash XS" and should be available as the first in the list and have white text (while the others are gray).
Nothing else changed
Request Submitted.
This fixture can be found in Eos Fixture Library v3.1.3build 5 (or newer build)
