Hello all!
I have a DJ Chauvet Obsession HP LED strobe with rotating gobo wheel.
I need a profile in EOS to properly patch this light, the only one I can find is for the regular "Obsession 2" which doesn't seem to be the right one.
Anyone have a compatible profile to use with this fixture?
Sean
Hi Sean. Do you have the exact DMX chart and profile you are looking for?
Thanks Chris, I've attached the DMX Chart but am unsure what the profile for this fixture is called.
somasean Agreed this is not in Eos currently. You can certainly build the profile yourself to get you through for right now.https://www.youtube.com/watch?v=b2RPVguE2PcBut if you'd like a formal profile made you can submit the DMX chart and manual to eos@etcconnect.comIt does take a bit to get built, tested and then added to the next fixture library update.
Thanks for the help Chris!
Did you managed to built your Profile?
Yes! I don't think I can post the file here though?
No Problem. You don't have to.Just wanted to make sure that you managed it by your self.
thanks mathilda
