Festoon_2_RGB_UM_rev3 Pixel Mode.pdf
Hello! I am looking for a fixture profile for a Chauvet Festoon 2 RGB Pixel. Ideally I would be able to customize it to the number of nodes in the strand.
Additional info, currently running a Gio Version 3.1.5 Build 8. Fixture Library 3.1.3.6 but hopefully updating to Fixture Library 3.1.5.11 before needing the different profile.
There is a Chauvet Festoon 2 RGB Pixel+ in Fixture library 3.1.5.11 Will this work with what you are discussing? Otherwise I can send in a request for the Chauvet Festoon 2 RGB Pixel.
My designer is adamant about the pixel profile, not the pixel+.
Understood. Request Submitted.
Thank you!
The dmx charts shared only have on page of the 9ch mode. If we are looking for the a Pixel+ mode then we need the dmx charts for that mode please.
Sorry for the very delayed response. I'd found an acceptable work around for my show at the time. I've attached a copy of the full manual to see if that gives you what you needed for the Pixel profile. Festoon_2_RGB_UM_Rev3.pdf
