Cameo Q-Spot 40 TW
There seems to be a mistake with the Cameo Q-spot 40 TW. The most extended mode has 8 channels in real-life instead of 7 in Capture. The intensity is 16bit on dmx 1 and 2.
Stange enough the exact same mistake was made in the Capture fixture library. I suspect that there has been an update to the fixture, so maybe add an extra 8 channel mode in stead of replacing it?
Also the last two parameters should be control channels as they set dimmer curves/responsesCLQS40TW_Cameo_DMX_Control_Table_02-2023.pdf
