HI !!!
Can i save a show made NOMAD on flash drive and open it on an element ?
Thanks !
Pace
HI !!!
Thanks !
Pace
Yes, you can!
Please remember that Element has some limitations. If your Nomad is running in Element mode you will already have the same limitations (e.g. only one cuelist).
If you have an older software version on your Element than on your Nomad you might need to safe the showfile in an older file format on your Nomad so Element can see it.
Here is a short summary of which version of the Eos software can load which showfile format: Eos Showfile Types
