Hi there,
Can you please make it possilbe to assign a cuelist to the MagicSheetbutton, that tells you in wich cue your cuelist currently is?
At the time it´s only possilbe to see in wich cuelist your MasterFaderPair is, if there´s a cuelist assigned to.
It would be nice be able to assign a Cuelist to the button, that says "Cue ", so that you have the ability to see the states of different cuelists at the same time in MagicSheets.
Thanks in advance
