With 3.2 we introduced sACN priority for the universe being stored within the show file itself rather than using a value defined in the shell. While this is great, there's still instances whereby you want multi-consoles to use the same files (Stored over network or shared over USB) and you want a distinguished device specific sACN priority.
Within the console settings (Or patch settings) can we have a toggle function to either take the default from the file setting or a priority in the device settings as the default rather than the only choice to use the one from the show file (Stored in patch).
