Adjust the X-Y-Z Focus Position on the Stickbeam
When converting a PT preset into a XYZ preset, the recorded target position is estimated where the beam first hits something, but the target position could be any position along the beam.
My idea is to have the ability to move this stored position along the beam as easy as with the fixture selected hold shift and scroll the mouse wheel to move the focus handle on the stickbeam.
  • Hey Mathilda, that would be one use case which is already possible with the click to focus offset. I’m thinking more of when upgrading old PT-Shows to XYZ. If you switch the preset mode to XYZ mode, the target is estimated from the PT values, which is not always the targeted coordinate, as the desk can’t know of course. What is my idea is to be able to adjust this focus position on along the beam to where it should be.
    greets,
  • You mean like a person that is standing in the Spot that has a upper body that need to bee lit and not there feet?
