Apply same effect to different groups and NOT have then be running the same instance of the effect
My wish: The ability to apply the same effect to multiple groups where each group maintains its own independent effect timing and spread, regardless of group size. Currently, grouping and offset only work correctly when all groups are the same size because the distribution is calculated mathematically across the whole selection. A true independent instance would allow Group A with 5 fixtures and Group B with 6 fixtures  and Group C with 4 fixtures to each run a full spread internally, completely independent of each other, without any relationship between groups.
Why? Sometimes we have a lot of groups all needing to run the same effect and copying the same effect isn’t good implement. In this case I would need the same effect probably 20 times for each effect.
