Under Review
Augment3d Camera tools
Rather than the large pop-up overlay I wonder if these wouldn't be more useful as sticky narrow column on the right.
When using the Look tools, Front, Back, Left, Right, Up, Down, I nearly always need to use Zoom to Selection immediately afterwards. Perhaps this could be added as an optional default behaviour. The only time it really isn't useful is when nothing is selected and the camera zooms right out, but that could easily be detected and zoom ignored in that case.
tt2
  • Work more efficiently. If there was a permanent narrow column of camera tools I wouldn't need to click to open it, then select a preset, then possibly select again to refocus on content that was already selected, then click once more to dismiss the overlay so I could work on what was behind it. With a fixture it would be nice if zoom to selection included the visible extent of the beam. tt2
  • Can you explain in a bit more detail what you are trying to do here? The popup doesn't close for me, so I can use one of these tools and straight away zoom to selection.
