Hello,
I control the intensity of my automated fixtures using inhibitive subs with intensity info coming from a cue stack. This is useful for me while busking specifically to be able to black out while manually running intensity effects. Using an additive sub the intensity effect will override the additive sub no matter the priority level of the sub. I would like the inhibitive sub buttons to work the same as additive bump buttons. While the inhibitive is full the fixtures flash to zero with the bottom bump button, but it would be great if the fixtures could also flash to full from the bottom bump button while the fader is down just like a normal additive sub works. If this feature could be added to 3.0 that would make my life so much better! Thank you!
