Cells of a Fixture should cause Direct Selects to show partial data
Sorry I can't remember if there's a proper term for "partial data" I'm referring to when only some of your channel selection is within a Group Palette or Preset instead of the Direct Select lighting up fully, it lights up as a gradient from darker to at the top to normal lit up at the bottom of the Direct Select Button.
I understand why it does this, my master channel doesn't have color parameters, or my cells don't have pan tilt parameters, but that's not information I need to be reminded of, and there is then no way to tell whether it's an indication that some of the multicell Channels in the selection are aren't in the Group/Palette/Preset, or if it is only doing it because of the cells but all of the Channels are in the Group/Palette/Preset. So the multi-cell channel should be treated as one fixture, and if that fixture is stored in the Group/Palette/Preset it should light up fully imo
- Steven
