Change opacity of text on direct select buttons so just icons can be visible
This would be a setting for apex devices where you select what you want on your smart direct select buttons. I find it annoying that I have to remove the text or have text overlaying the images when I could just set the text opacity to be 0 percent so that just the icons are visible. It would be much nicer!
