Circuits in fader
hello, would it be possible to make it so that we can assign a channel to a fader, and that the fader follows the level of the channel during the restitution? it would be super useful to use the motorized faders
thanks a lot
  • Thank you for your time !
    I'm on a creation for theater and I wanted to have cues but still be able to keep the levels handy, I'm lucky to create on Apex 20 and have a good number of faders, and the show will run for smaller places on Nomad but with motorized faders and that seems to me to be the most intuitive, because also, the director wants to be able to correct the light states at any time.
  • In this work around the Fader position is always linked to the sACN level of the defined Address.
    The Submaster itself could be empty, and it will still work.
    The biggest problem is, if you put the Channel with the responding sACN-Address in the Submaster, you could end up to slight errors in level.
    Because you double things up when you move the Fader by Hand.
    The question that i would ask is, why would one do someting like that, having a Fader that moves in response to a channel?
    Can you explain a bit more what you are try to achive?
  • thank you very much for the idea ! But do you know how to be able to both regain control, and ensure that on the next core affect this circuit the cue regains control of the fader ?
  • There is a way around to do it already.
    If you make your way via a showcontroll event.
