Custom Direct Select > Command
In addition to the Button item, it would be really helpful if we had a command item like in Magic sheets, with the same label and Icon options in my other feature request. This would let us change another Custom Direct Select without having to make snapshots for example. In this case, we could have two CDS panels, one that has the command "Tab X Custom Direct Select 3/401" which would change the other CDS to Direct Select 3 at position 401.
  • I second this as a feature. Being able to set commands in Custom DS tile would certainly help with workflows. The current need to make a Macro and then map it to the tile is pretty inefficient and leads to wasted Macros. E.G. Making 10 macros just for swapping veiws in a Magic sheet that all read "Magic_Sheet ### Part ### Enter"
