Disabling of XYZ if not in use
Hello, I recently had a problem where I had accidentally recorded some channels with XYZ Format enabled in some cues. This led to instant snapping of p/t values of the fixtures, I don't know if that is expected. I would like to be able to remove the XYZ encoders and the XYZ Enable button from channels that aren't using this functionality. A simple Enable/Disable would be great on a channel basis under attributes in patch.
This had me going in blind mid-show to fix this ahead of time as I didn't notice until we had people in the audience.
All the best!
-p
