Hello all,
Thank you for your phenomenal work on the new direct select system in Eos 3.1.
I would like to use the "jump to" option in custom direct selects to switch between several custom direct select layouts I have made. I cannot do this right now because the "jump to" buttons only display the number and page number of the custom direct select they point at, and that is not intuitive enough. Displaying the label on the jump to box like a palette does would be ideal.
Alternatively, you could make the jump to buttons have customizable colors so that I could color code where each jump to command will be taking me to. OR you could even use your new Icons so that I can denote where each jump leads via icons. I just need some kind of organizational tool here. Something.
