Under Review
Edit attributes visible in real time on Augument3d..
Hi
Currently when you  edit attributes, in patch,  to fixture, the fixture go to home position ... in the case of edit pan and tilt I think it would be more immediate to choose the edit if you could immediately see the result on Augument3d... currently there is only a small flash and you have to go back to the live to check if the change made is correct.
MLJ
