Element Mode Lying To Me About Automark
Hello,
This is a suggestion to change something that exists, so not a feature request. I'm going to assume this is okay? And will understand if I get yelled at or this gets deleted without explanation.
The following is my strong opinion.
In Element mode on Nomad, which I live in because of a bug in Eos mode that was apparently fixed 2 years ago, Element tells me automark is disabled, but it's lying. Here's what it says:
Mark Time: Disabled
And then I can change it to whatever number I wish, but I prefer to keep it disabled because automark and I got divorced a while back. We don't talk anymore. So I keep automark disabled. But automark, like an abusive ex girlfriend, she sticks around long after she's supposed to be gone. She keeps breaking my stuff. I can't get her to go away. So I end up on this forum. Through this forum I find out that thing I talked about above was lying to me the whole time. I have to go into Eos console mode to get her to go away. Here's what I mean about the lying:
"Mark Time: Disabled" means mark time is disabled. That means mark is disabled. Mark Disabled means mark time is disabled. Mark Time Disabled means mark is disabled. Disabled means disabled. Disabled means doesn't do anything. Disabled means turned off. Mark Time Disabled means turned off. Here's what "disabled" actually means:
Mark Time Disabled = Mark is enabled and follows cue timing
So here's my proposal. Let's change it so that it says:
Mark Time: Cue Timing
Because if the current "Disabled" selection doesn't disable anything, it shouldn't be called "disabled". If what it actually does is it sets the automark time to follow the cue timing, it should say that.
It doesn't.
  • Seriously. What is with the culture on this forum? How does this get 3 downvotes? No critique you could come up with against this post actually invalidates the post. It's well written, identifies an obvious UI problem, and presents a quick, tangible, simple, and clear solution. UI labels should say what they do. This one is extremely misleading. How could you downvote this? Any nitpick about the tone or presentation style is just nitpicking.
    This stuff is partly the reason why I dislike this forum. My other post in this sub-forum here, which heavily criticized A3D for not having any Undo functionality whatsoever, was met with the same type of silent opposition. You don't like my tone? You don't like that I dare speak down to ETC? You can feel that way. But that doesn't change the fact that that it raises a valid point.
    If the complaint warranting downvotes on this one is that it isn't technically a feature request, think better. Forcing every single piece of feedback into this tiny box that is a "proper and correct feature request" is counterproductive and does not serve the software. It just serves the rules of some forum. The goal should be making the software the best it can possible be, not pleasing the forum gods.
